Truck stalls or RPMs when i come to a stop
Old Dec 5, 2007 | 12:16 PM
Iansram's Avatar
Iansram
Default Truck stalls or RPMs when i come to a stop
Well when i slow down or come to a stop my trucks RPMs slow way down and alot of the times it stalls. I am able to start it up with no problems but not sure whats going on. i was getting on the road after a stop last night and my check engin light came on and then i lost my transmission. I was not able to go into any gears for a few minuts then i got it to work and drove to the dealer. the dealer hooked my truck up to the computer and got a code P0700. a common trouble he was able to reset it. So can anybody help me out?
Old Dec 5, 2007 | 01:50 PM
Drew's Avatar
Drew
Default RE: Truck stalls or RPMs when i come to a stop
what year truck. . .each generation has its own issues.
Old Dec 5, 2007 | 03:34 PM
Iansram's Avatar
Iansram
I am sorry i have a 2005 dodge ramm 1500
Old Dec 5, 2007 | 03:36 PM
Iansram's Avatar
Iansram
2005 Dodge Ram
Old Dec 5, 2007 | 03:37 PM
Drew's Avatar
Drew
moving to the 3rd gen area for better visability
Old Dec 5, 2007 | 07:42 PM
HammerZ71's Avatar
HammerZ71
The dealer should have known to re-flash your PCM while he had it. There is a TSB about low idle and stalling. There is a software update that all dealers have to fix the problem...
Old Dec 5, 2007 | 08:09 PM
soccerstud's Avatar
soccerstud
I had this problem with a 88 ford ranger that i had, took it in and found out thatapiston was cracked and jammed in the resesive position and it caused my whole drivetrain to go, the transmisiion ended up needing to be replaced after they replaced the piston. I'd have them check your pistons and rings just to be sure and maybe grease them. It cost me about 3000 to fix, so not very cheap.
Old Dec 5, 2007 | 08:26 PM
XxSilentHawk99xX's Avatar
XxSilentHawk99xX
I have a similar problem when putting the truck into reverse on hills. Occasionally, the transmission either fails or doesnt cooperate and the truck stalls out.
Old Dec 5, 2007 | 09:52 PM
MoparRob's Avatar
MoparRob
ORIGINAL: soccerstud
lol how would they manage that one???
Old Dec 5, 2007 | 10:15 PM
HammerZ71's Avatar
HammerZ71
ORIGINAL: MoparRob
Oh man, here we go, I'm just waitin' for Hank to reply to this post.
and Ian, 80% of the people with low idle/stalling issues are fixed by a software update. The other things to look at are a bad EGR valve or a really dirty throttle body. It's always one of the three.
