Spray in bedliner
Old Dec 5, 2007 | 02:48 PM
DaHipaKea1313's Avatar
DaHipaKea1313
Default Spray in bedliner
Hey all how is everyone?? Well I'm over here in Iraq again and this time for a bit longer, but also for the last time too. I'll retire when I get back. Got a spray-in-bedliner question, what seems to be the best for the $$ I use to have what they called "Scorpian" spray-in liner when I was out in AZ. But I'm east now and want a liner when I get home. I have the drop-in kind now and do not like it at all.
Stay cool, H-
Old Dec 5, 2007 | 03:37 PM
Hemiriden's Avatar
Hemiriden
Default RE: Spray in bedliner
I have a reflex liner (http://www.langeman.com/) I love it. IT has a rubber surface so nothing slides. Unlike the plastic and other sprayins, which usualy things slide everywhere with the slightest nudge of the wheel or pedal. The other nice thing about them is you can get them to match your exsisting paint. Your not stuck with only black.
That is just my opinion, and i haul anything and everything in my truck. Pallets of products, bags of cement, cinder block, ect. been 2 years and still holds strong with no tears, cuts, or anything.
Old Dec 5, 2007 | 03:42 PM
06Mopar's Avatar
06Mopar
LINE X SPRAY ON BEDLINER....... You dont want to get a colored spray in liner because they fade very fast.... The Line X offers a lifetime warranty as long as you own your truck..
Old Dec 5, 2007 | 03:48 PM
bwhite757's Avatar
bwhite757
The general consensus around here is either Rhino or Line-X. Personally I have a Premium-One, the dealership put it in before I bought the truck. I'm looking at getting a bedrug however, I really like the way they look....
Old Dec 5, 2007 | 03:53 PM
Hemiriden's Avatar
Hemiriden
ORIGINAL: 06Mopar
That is not true. The color NEVER fades. It can't it is not painted. The liner its self is died before spraying so the color is completely through. Reflex colorant is precisely metered and pressure-injected into the fluid stream, producing total, thru-n-thru color dispersion. By using OEM automotive grade paint toners and pigments.
Second Mine also came with a lifetime warranty. IF i have any peeling, cutting or any problem. They fix it. I've had ONE incident and it was my fault and caused by a forklift dragging a 2,350lb pallet out of the truck without lifting it up all the way. They filled in the damaged areas making it look new... Cost: $0.00 Time:12 hours.
Old Dec 6, 2007 | 08:56 AM
ray97's Avatar
ray97
I'm going with the line-x as soon as I can. Stay safe and do what you gotta do to get through the time. I did 2 tours over thereand retired after my second one also.
Old Dec 6, 2007 | 08:59 AM
tdmopar59's Avatar
tdmopar59
yea i hear good about line-x and rhino..... i will prolly get one eventually... but for now i will ruin the plastic one
BTW: Thanks for serving [sm=americanasmiley.gif]
