Eleectric cut-out problem!
I've had my cut out since June and had been working fine until about september, when i started to notice it wasnt closing all the way and i can now hear a leak. when i HOLD the switch to shut, it sounds wonderful. but as soon as i let go, its as if the cut-out opens slightly and it sounds real bad & cheap. i've been dealing with it since september, but it finally got to me after driving 4 hours back from school the other day....i tried oiling it up and cleaning it, but still sounds "hollow" any advise from the cut-out guys?
yes that is what i have heard that is bad about getting them.....metal expands and shrinks with heat, so eventually you will not get a true fit causing it to leak.. The only solution is to go back to a traditional exhaust.....solid pipe
its a DMH cutout. but its a really good product, alot of good reviews, but i guess with the weather here in NJ something happened. but thanks for the input guys, i'll probably hit up DMH and see what the deal is with their warranty.
I would call DMH too. Sounds like you just got a bad pressure spring. It stays closed because the motor is forcing it shut, but when you release it the spring is supposed to hold it in place. Probably, just a bum part and the warranty will cover it.
What the duece? I know I clicked onthe "What you did to your Ram today" topioc. Oh well my bad...
Trending Topics
ORIGINAL: VaderPainter
I went and picked up my tonneau cover today and installed it, with the guy I purchased it from. The black paint was a perfect match for my truck. Seems he purchased from the dealer when he bought his truck new in 2005 for well over $1200. I could not have been happier when it went on without a problem and matched the paint perfectly for the low price of $500. I will get some updated pics of the truck up in a couple of weeks once I have a chance to go and do some more shots.
I think you clicked the wrong thread
I have had no problem with mine. I have heard of a very few number of guys having problems and they send a NEW unit out right away, #1 reason I went with them. 4 year warranty.
