Ignition key will not turn
Old Dec 9, 2007 | 10:09 AM
RamGator's Avatar
RamGator
Default Ignition key will not turn
Last night when I came out of the woods from deer hunting and got in my truck, the ignition key will not turn. The key goes in fine (meaning feels normal) but will not turn forwards or backwards. I've tried turning the steering wheel, played with the gear shift, rocked the entire truck back and forth etc to no avail. I even had two other people try it just to make sure I hadn't lost it for a little bit. Any ideas?
2004 Ram 2500 Quad cab 4x4 ~29K miles
Old Dec 9, 2007 | 12:19 PM
RamGator's Avatar
RamGator
Default RE: Ignition key will not turn (update)
I squirted graphite dust into the key hole and tapped the key a dozen times with a rubber mallett (found this tip online referring to Dodge vans) and finally got the key to turn. Its still very sticky but it will turn now with a few aggressive jiggles.
I guess Dodge still hasn't fixed a very old problem of theirs.
Old Dec 14, 2007 | 07:27 PM
Silver Eagle's Avatar
Silver Eagle
Did you have your foot on the brake pedal?
Old Dec 14, 2007 | 07:56 PM
Parts/Service's Avatar
Parts/Service
Sounds like you need to have new tumblers installed in the cylinder or be taken apart to check for damage.Is really easyto take apart Let me know if you need directions on taking it out and apart......
Old Dec 14, 2007 | 08:31 PM
dieseldoc1's Avatar
dieseldoc1
is it all the way in park? is it still in the woods? how did u move it? wrecker?what happened the suspense is killing me!
