Ram SXT?
Old Dec 12, 2007 | 12:53 PM
moparman2k2's Avatar
moparman2k2
Default Ram SXT?
Anyone have a Ram SXT? What's different about it compared to the other trims? any Pictures? thanks!
Old Dec 12, 2007 | 01:12 PM
drhunter's Avatar
drhunter
Default RE: Ram SXT?
I had an '02 Dodge Dakota SXT. It had a tilt steering wheel, a cd player and an AC. Manual windows/locks etc. Unless they changed then thats about what you are looking at. Oh yea, it also had some fender flares.
Old Dec 13, 2007 | 03:31 AM
thebean's Avatar
thebean
Don't have one, but I've seen a few around, all reg cab short beds. Trim level is between ST and SLT, seems to be available on RC andQC. From edmunds.com:
AGR
SXT Group
Includes SXT badge, 17" x 8.0" chrome-clad steel wheels, cloth 40/20/40 split bench seat with YES Essential seat fabric, carpet floor covering, fold-away power heated mirrors, power door locks, power windows with driver's one-touch down feature and speed control. INCLUDES CKE and P9 and WF2 and NHM. NOT AVAILABLE with AS9, XJL, XEA, K17, GPD
AGD
SXT Plus Group
Includes 17" x 8.0" chrome clad aluminum wheels, bright grille, rear sliding window and remote keyless entry. REQUIRES AGR. INCLUDES GFD. NOT AVAILABLE with AA3, AS9.
Better to see it all in context no edmunds.com:
http://www.edmunds.com/apps/newtmv/T...leid=100811038
Or on dodge.com (has a photo):
http://www.dodge.com/en/2008/ram_150...sxt/index.html
Aesthetically, most notable difference is the SXT sticker on the rear quarter. Also, top of front bumper is black like the ST (vs body color on SLT).
Old Dec 13, 2007 | 02:50 PM
redtruck2500's Avatar
redtruck2500
I have the SXT package . 2500 HD Reg. cab 8 ft. bed Hemi 6 sp. man.
Old Dec 13, 2007 | 05:11 PM
1 Big B's Avatar
1 Big B
Ihave an SXT in a 08 Mega Cab. It doesn't seem to be the stripped down version that I hear other people talking about.
infinity sound
CD with sat radio
power drivers seat
under hood lamp
glove box lamp
auto trany
Skid plate
I did get something call popular euipment group or somwthing and the salesmanseem surprised at what had changed. I just went in looking for certian option and when I found the right truck bought it. It did have the UGLYSXT sticker on the bed that I HATED, but 10 minutes at the local body shop and they were gone and No Damage (like I'm sure I would have done if I tried it myself).
Hope this helps
B
Old Jan 6, 2008 | 11:52 AM
larbec7's Avatar
larbec7
I am told it is somewhere between the SL and SLT. I too am looking to purchase one. I will copy and paste the sticker for you. I am getting a reg cab in black. It seems to be a nice truck in my humble opinion.
Vehicle Option-All Standard Equipment Code Description Code Description Code Description APAS Monotone Paint BAZS 136 Amp Alternator BCES 600 Amp Maintenance Free Battery BRRS 4 Wheel Disc Rr Anti-Lock Brakes CGDS Front Height Adjust Shoulder Belts CG3S Advanced Multistage Front Air Bags** CSPS Passenger Assist Handle CU3S Behind the Seat Storage / Bin DH5S Elec Shift-on-the-Fly P/Time T/Case DJMS 205MM HD Front Axle DMDS 3.55 Axle Ratio DRBS Corporate 9.25 LD Rear Axle GACS Tinted Glass Windows GJDS Rear Fixed Window GNAS Rear View Day/Night Mirror GXXS Sentry Key Theft Deterrent System HAAS Air Conditioning HGBS Dash Liner Insulation HGFS Floor Tunnel Insulation JAYS Instrument Cluster w/Tach JBFS Instrument Panel Black Bezel JCBS 120 MPH Primary Speedometer JHAS Var Intermittent Windshield Wipers JJAS Cigar Lighter JJBS Dual Note Electric Horns JJJS 12V Auxiliary Power Outlet JKYS Power Accessory Delay JP8S Manual Adjust Seats LABS Tire Pressure Monitoring Warning LP LMAS Halogen Headlamps LPES Cargo Lamp MCLS Gray Upper Fascia MGAS Ram's Head Badge MUSS 4X4 Badge MWDS Removable Tailgate w/Caliper Latches MXBS Front Air Dam MXCS Front Air Close Out Panel NFWS 26 Gallon Fuel Tank QXRS Brilliant Black Crystal Pearl Coat RCDS 4 Speakers REFS AM/FM Compact Disc Radio SBAS Power Rack and Pinion Steering SCFS 4-Spoke Steering Wheel SFBS Front Heavy Duty Shock Absorbers SGBS Rear Heavy Duty Shock Absorbers SHAS Front Stabilizer Bar SUAS Tilt Steering Column TBBS Full Size Spare Tire TBMS Tire Carrier Winch WF1S 17 Steel Spare Wheel XA8S Non Adjustable Pedals XBSS Pickup Box XFUS Trailer Tow w/4-Pin Connector Wiring X81S Instrument Panel Parts Module X88S Tire Wheel Parts Module YAAS Build To U S Market Specifications Z6AS GVW Rating - 6350# 1AAS U.S. Dealer Retail 163S Zone 63-Dallas 5I4S Four Wheel Drive (4WD)/(4X4) 5I7S Price Class L 5RES Add Light Group 5ZES 6 1/2 FT. Cargo Box 5ZJS Regular Cab 5ZLS 1500 GVW 5ZWS DR-Vehicle Family 594S Vehicle Order Tracking 6USS Label - U.S. Specifications 644S Texas State Code 944S Texas State Code Optional Equipment Code Description Code Description Code Description *P9 Cloth 40/20/40 Split Bench Seat -D5 Med Slate Gray AGRP SXT Group CBEP 40/20/40 Split Bench Seat CKEP Floor Covering Carpet CLAP Front Floor Mats DGQ 5-Spd Automatic 545RFE Transmission EVE 4.7L V8 Engine GTSP Power Heated Mirrors, Fold-Away GXMP Remote Keyless Entry JPBP Power Locks JPDP Power Windows, Driver One-Touch MBFP Bright Rear Bumper MCTP Bright Front Bumper MDAP Front License Plate Bracket MFDP Bright Grille MGDP SXT Badge NAA Federal Emissions NHBP Auxiliary Transmission Oil Cooler NHMP Speed Control NHNP Electronically Controlled Throttle NZDP Next Generation Engine Controller PXRA Brilliant Black Crystal Pearl Coat RDDP Fixed Long Mast Antenna TTMP P265/70R17 BSW All Season Tires TZAP Goodyear Brand Tires WF2P 17X8.0 Steel Chrome Clad Wheels WMJP Center Hub XBNP Tip Start XGWP YES Essentials(R) Seat Fabric XKNA Flexible Fuel Vehicle YGNA 4 Additional Gallons of Gas ZDSP Spring - Left Rear ZFCP Spring - Left Front ZSSP Spring - Right Rear ZUBP Spring - Right Front 0HGA FAM: DR TRACKING: 70619T39 MY:2008 2TBA Customer Preferred Package 2TB 24B Customer Preferred Package 24B 4KZP 4X4 Tracking 42DP ST. LOUIS ASSEMBLY PLANT NORTH 5A6P Waterbase Paint 6F9 Paint Order Code
Old Jan 6, 2008 | 01:22 PM
kenny c's Avatar
kenny c
ORIGINAL: larbec7
I just got one. SXT, Hemi, Mega Cab, 4x4, auto - $26k OTD. It was one of those specials that the dealer ran in the paper with $7k in rebates and another $5k in dealer incentives... $37k sticker - 12k off - 1k trade = $26k with TTL. I'm very happy with the deal... especially the LIFETIME powertrain warranty. I went to the dealer looking to get a Cummins but they only had a 100k mile warranty on the motor and the rest was 36/36.
