rear pinion seal leaking at 30,000?
Old Dec 12, 2007 | 03:23 PM
7floorsofhell's Avatar
7floorsofhell
Default rear pinion seal leaking at 30,000?
would increased horsepower blow out a rear pinion seal? I have noticed a small vibration on the highway which i believed was the driveshaft. I think this may have confirmed my suspicions of this possibly causing the seal to now leak. I am putting out 535 HP at the rear but i don't believe that is the reason this happened. any ideas?
Old Dec 12, 2007 | 04:22 PM
hemiyellow's Avatar
hemiyellow
DC Insider
Default RE: rear pinion seal leaking at 30,000?
might wanna replace that aluminum driveshaft with a steel driveshaft (if you have an aluminum one anyways)....aluminum driveshafts are somewhat known for throwing weights and becoming unbalanced so it could be possible i guess
Old Dec 12, 2007 | 04:25 PM
CarGuyOhio's Avatar
CarGuyOhio
Should not have hurt the seal. Dodge rears are bad for a few things, one of them is the seals. I had a GC that was dripping at 69K.
Old Dec 12, 2007 | 06:02 PM
kenihemi's Avatar
kenihemi
Mine started leaking at around 11K.
