Truck not switching to 4 wheel drive
Old Dec 14, 2007 | 08:17 AM
SWOS Chief's Avatar
SWOS Chief
Default Truck not switching to 4 wheel drive
Had the truck in 4 hi last night to run some errands in the snow. This morning went out and took it out of 4 when I left house, got where I was going and had to put it back in. A couple clunks later, no four wheel drive, 4x4 light flashes (including when shift to 4 low). Yes I was going slow when I shifted to 4 (around 10mph).
Here's my worry, if I take it to the dealership are they going to say tough s*&t since I have the lift? Suggestions?
Old Dec 14, 2007 | 10:10 AM
tdmopar59's Avatar
tdmopar59
Default RE: Truck not switching to 4 wheel drive
i would wait to see what parts/service has to say about the dealerships... as far as i know as long as the lift didnt cause the problem they cant hold it accountable for anything.... do you have electronic or shift?
Old Dec 14, 2007 | 08:21 PM
Broich's Avatar
Broich
Had the same problem on my 06, they replaced some front actuator. Said they have never seen thatneeded before.
Old Dec 14, 2007 | 11:44 PM
HammerZ71's Avatar
HammerZ71
It's going to be the actuator. Has nothing to do with a suspension modification, so don't let them not honor it.
And Broich, your dealer is full of sh*t, I hear it's fairly common on 06s & 07s.
Old Dec 15, 2007 | 12:38 AM
SWOS Chief's Avatar
SWOS Chief
Alright, thanks guys, will call for an appointment on Monday. Odd, I here the click when I turn the switch and friend said it looks like it is in 4, but the light keeps flashing.
Old Dec 15, 2007 | 12:50 AM
7floorsofhell's Avatar
7floorsofhell
THE 4X4 IS VACUUM FED IF PUSH BUTTON, HAD MY AVALANCHE DO THAT, ITS THE ACTUATOR, THE VACUUM TRIES FOR ABOUT 3 SECS BUT NOTHING. ONCE IT STICKS, MINE NEVER UNSTUCK TILL I DID IT FOR IT. EASY FIX
Old Dec 15, 2007 | 09:05 AM
HammerZ71's Avatar
HammerZ71
Yea, I'm sure of it. I've blown actuators in my ATVs a few times and it's the exact same symptoms...
Old Dec 17, 2007 | 12:39 PM
SWOS Chief's Avatar
SWOS Chief
Ok service guy's. Will dodge tell me they won't pay to fix it if it is the actuator since I lifted my truck? Don't want to take it in to get done and drive out with a $1000 bill because the warranty is void from the lift.
Old Dec 17, 2007 | 12:57 PM
HammerZ71's Avatar
HammerZ71
Only if they can PROVE that the lift caused the problem...
