Water in oil?
Old Dec 15, 2007 | 11:54 AM
rodneyw71's Avatar
rodneyw71
Default Water in oil?
This morning I was checking the fluids in my truck, I noticed it was a little low on oil, I took the cap off to add some, and noticed a white paste in the part where the oil went. I didn't see any on the dip stick, does anybody have any idea what this could be?
Old Dec 16, 2007 | 12:00 AM
marv02's Avatar
marv02
Default RE: Water in oil?
It could be just some moisture that builds Up in the crank case if you take it for a good long dirve the heat of the engine should dry the water build up.
If you dont drive it enough to build up some heat this will happen I drive mine at least 40 miles every day now 20 miles to work 20 back I notice it has the white build up on the OIL filler Cap sometimes ALSO no big deal.
Keep a eye on it check the Radiator for oil film it could be a sign of a head gasket going bad or a intake manafold gasket mite be giong bad have you over heated the truck and how much for how long the 3.7 has aluminm heads on a cast iron block good and bad but if you over heat it could be very bad.
Old Dec 16, 2007 | 08:12 AM
rodneyw71's Avatar
rodneyw71
I talked to my brother after I posted this, he has a '02 Dodge Ram, and he said his did the same thing. I noticed the pic. under your name, are you in AMMO?
Old Dec 16, 2007 | 11:10 AM
marv02's Avatar
marv02
No I not but I am a exnavy Now I still working for the goverment on experimental Aircrafts One off stuff.
I see all kinda of cool stuff.
