Leaking water pump at 57K
Old Dec 17, 2007 | 07:59 AM
Splashman's Avatar
Splashman
Default Leaking water pump at 57K
My water pump is leaking. Not sure where from but I found it odd that it's bad already at 57K miles. I'm making the assumption that this wouldn't be covered on the powertrain warranty? It's an 2004 so my bumper to bumper is long gone.
Looks like they are about $65 to replace. Any tricks or tips on changing it out? This is definitely not my first water pump change.... however this is the first time I'm working on the HEMI... all the other bugs were fixed under warranty.
Old Dec 17, 2007 | 05:07 PM
HammerZ71's Avatar
HammerZ71
Default RE: Leaking water pump at 57K
Have not had to do one on a Hemi, either, but water pumps are a cheap easy fix. I'm sure if you've done one before, you won't have any problems. It's probably just a fluke, I've not read anything where water pumps are an issue on our trucks.
I had a Ford Astro Van as a company vehicle when I owned my business in Ga.a few years back. Ate them up, I was going to Advanced Auto for one almost as often as I was changing the oil. Got towhere I was keeping a spare one in theback of the van...
