86 CJ7 With '04 Hemi -Need help installing Tach
Old Dec 18, 2007 | 05:29 PM
jhart's Avatar
jhart
Default 86 CJ7 With '04 Hemi -Need help installing Tach
Ok, Heres the deal. I put a hemi out of an 04 Ram into my 86 Jeep CJ7. It is up and running. I am trying to install a tach in it but the problem is most aftermarket tachs are designed to read all of thecylinders ignition signals and then dive that by the number of cylinders. But the hemi has a coil for each cylinder and most tachs only are selectable for 4, 6 or 8 cylinders. Even if I select 4, it will be 1/4 the actual RPM. Any suggestions? I can make it work but I dont want so spend an arm and a leg to get it to work.
thank in advance
J
Old Dec 19, 2007 | 12:28 PM
railman87's Avatar
railman87
Default RE: 86 CJ7 With '04 Hemi -Need help installing Tach
Give this link a try from autometer.
http://www.autometer.com/download_instruction/561.pdf
This will give you an idea of what you are doing.
Old Dec 19, 2007 | 01:04 PM
TANKZ400's Avatar
TANKZ400
Its got a rev limter.
Old Dec 19, 2007 | 01:20 PM
tdmopar59's Avatar
tdmopar59
wow this sounds like a sick project... any pics???? i would just do a few searches for an aftermarket tach that would work for the ram.... did you already do this?... i would think so...
Old Dec 19, 2007 | 05:55 PM
oefootball_70's Avatar
oefootball_70
dang that sounds like a bomb *** project
