two gas tanks ?
Old Dec 20, 2007 | 12:00 PM
Hemiriden's Avatar
Hemiriden
Default RE: two gas tanks ?
ORIGINAL: chongo
ORIGINAL: bwhite757
ORIGINAL: manualagain
but the new Ram with its 34 gallon tank took me 385 miles on the first tank so I'm ok with this setup.
385 on a 35 gallon tank?!!? Youch! I get that on a regular basis on my 25 gallon.... [sm=proof.gif]
HA - I get about 330-340 on my 34 gallon tank - thats strictly city driving! - Driving to Alabama in the next few days and it's a relatively flat stretch so I should get pretty decent mpg - like 15-16.
WOW!!! Your gas milage sucks on those 35g tanks. I'm with bwhite757.. I have the 26 Gal Tank on my 05 Hemi.. I fill up at 1/4 tank. IT ranges from 280 - 320 Miles. (the few times i get to the gas light i'm pushing 340-350 miles) I live in orlando right now and drive regular stop and go traffic... I average 15-16 MPG... City... on the highway i push upwards to 18MPG... maybe i'm just a light foot IDK... but 340 miles on a 35 GAL seems bad... even 385 is not that great. (11 MPG average).And with the newHEMI's MDS system you should be killing me even if only by 1 or 2 MPG....All i can figure is the extra weight gives you less MPG when full...
ON average...[*]1 gallon of water equals 8.33 lbs.[*]1 gallon of gasoline equals 5.8 to 6.5 lbs.
You have 10 extra gallons of gas is 58 - 65LBS... not much but maybe it could make a difference...
Old Dec 20, 2007 | 12:11 PM
Kev_n_AZ's Avatar
Kev_n_AZ
sddunn2
how big were the tanks?
my brothers ford has 2 tanks that hold a combined amount of 30 gallons.
my old chevy 3/4 hvy had 1 32 gal.
my old dodge ctd (that I now drive ) has 1 24 gal
1 or 2 tanks wont make the diff on fuel milage guys.
use your brains!!!
its the driver, vehicle weight, drag (empty or loaded), computer settings, etc.
my 93 ctd gets 400miles + on 1 24 gallon tank.
try a smarty or another programmer and see if you can dial in the best mpg out there..
Old Dec 20, 2007 | 01:26 PM
chongo's Avatar
chongo
It's a 34 gal tank - I don't have mds - and my truck weighs in at almost 6700lbswith 3.73 gears - I don't have a lead foot - I drive it pretty easy - but with the gearing, bigger tires that I am running and the weight of the truck - it's not going to get good mpg - but on the hwy I can get 14-15 at 75 - and 15.5-16.5 at 65. I only have to fill up once a week (every sunday) so it's not to bad. But if I could have a second 34 gallon tank - I probably would - it would be nice to only have to fill up every 2 weeks.
Old Dec 20, 2007 | 01:34 PM
Kev_n_AZ's Avatar
Kev_n_AZ
aluminum diamond plate for the bed would be the better choice for a 2nd tank.
Old Dec 20, 2007 | 02:19 PM
chongo's Avatar
chongo
Those are the big tanks that alot of diesels have right - I thought those weren't DOT approved for gassers? If they are - do they just work as a second tank flowing through the same lines as the underside gas tank?
Old Dec 20, 2007 | 07:39 PM
manualagain's Avatar
manualagain
As I noted the 385 miles was the first 385 miles. I anticipate the milage will improve with break in.
Old Dec 20, 2007 | 07:54 PM
thehemiman12345's Avatar
thehemiman12345
yeah my friend just bout a 94 ford and its got 2 tanks.....only uses the front one though, i think he said they are both 19 gallons.....
Old Dec 20, 2007 | 08:57 PM
JD1500's Avatar
JD1500
I am glad to only have one tank now. its the same capacity as my truck with two, with 1 less fuel pump and filter to go bad
Old Dec 21, 2007 | 12:45 AM
sddunn2's Avatar
sddunn2
Ya I dont remember how big the tanks were .. It was just a thought .I have never figured out my mpg but I dont think it is very good maybe 500km on a tank could be more ??? I will have to check it out . I do know that I have the big tank though.
Old Dec 21, 2007 | 01:54 AM
michaelahess's Avatar
michaelahess
I always get over 500 miles in my '06 1500 Mega with 36 gal tank, even if its mostly city driving. My '96 5.9 on the other hand, maybe 250 miles and I think it's a 26 gal.
