lower a 2008 1 inch
Old 12-20-2007 | 09:32 PM
tjharder's Avatar
tjharder
Default lower a 2008 1 inch
I need help. 2008 Regular Cab SWB 1500 w/ 20" wheels. I need to lower the back about 1 inch to clear my garage opening. I do not want to spend a lot of money. Any suggestions would be greatly appreciated. Thanks in advance.
Old 12-20-2007 | 09:40 PM
thehemiman12345's Avatar
thehemiman12345
Default RE: lower a 2008 1 inch
17 inch wheels perhaps?......i bet you could do something with the leafs though.....
Old 12-20-2007 | 09:41 PM
M15's Avatar
M15
The cheapest way would be to just throw some weight in the back.
Old 12-20-2007 | 09:47 PM
jestyr's Avatar
jestyr
best way to do it would be use some sort of lowering kit. you could also take out a leaf spring...but it would prob ride rougher.
Old 12-20-2007 | 10:21 PM
Hemiroid's Avatar
Hemiroid
heat the springs baby oooo yaaaaa
Old 12-20-2007 | 11:43 PM
kx250frider617's Avatar
kx250frider617
1 1/2 " lowering shackles by belltech
Old 12-22-2007 | 04:25 PM
RaiderJay6's Avatar
RaiderJay6
www.slammed1.com has rear drop shackles that will drop you down anout an inch and a half. Thats what I have.
Old 12-22-2007 | 11:05 PM
stratusguy02's Avatar
stratusguy02
ORIGINAL: Hemiroid
I can't believe you guys haven't heard of doing this!! Torch those springs and watch the front end drop. It is pretty ghetto, but it works. I am pretty sure he needs the front end down to clear the garage, not the bed.
Old 12-23-2007 | 01:50 AM
tdmopar59's Avatar
tdmopar59
ORIGINAL: RaiderJay6
this is what i would reccomend as well...
Old 12-23-2007 | 04:01 PM
sschevy400's Avatar
sschevy400
Don't heat your springs....Its just not a good idea. Do it correctly like mentioned above.
Quick Reply: lower a 2008 1 inch
