What does P0404 mean
I have the code P0404coming up on myOn Board Diagnostics and it says on the code chart that P0404 means "Exhaust Gas Recirculation Circuit Range/Performance" I have noclue what that means..... anybody have any idea. Thanks Glenn
RE: What does P0404 mean
Bump to Top...... Anybody have any ideas at all??????
What year is your truck? Maybe you need to service the EGR?
This may or may not help I'm not entirely sure, but I'm a Ford diesel tech and that code means the same thing on the trucks I work on, and usually it is a stuck EGR valve. Now that may or may not be the case with your truck so I would have it checked out by the dealership or a repair shop to be sure.
The Truck is still under warranty, is that something that would be covered?
Yes, it should be covered.
My '05 Ram 1500 QC 4X4 just threw the same code over the weekend. I reset the PCM and it cleared the code, the light came back on after 5 minutes then went back out. Probably a slight variation in the voltage that's causing the light to illuminate. I'll have it at the dealer soon, as I also have a slight leak in the power steering system. Either at the pump (most likely) or the steering box. |
Thanks for the help Guys.
thats the egr valve. It happened to me a month ago. At the time I had 38k miles on my truck and they said it wasnt under the warranty.:(
Originally Posted by bobbylight
(Post 1096456)
Interesting, mine threw the same code Thursday after I unplugged the battery to do some work. I've got 40k on my '04....odd that we're seeing this similar problem around the same time....oh well, Dodge dealer has the EGR in stock for 70 bucks, give me something to do tonight.
