Bigger Tires Worse MPG
Old Dec 28, 2007 | 09:42 AM
HankL's Avatar
HankL
Default RE: Bigger Tires Worse MPG
It does not help right now
but the new law just signed by Pres Bush
requires that new tires get a rolling resistance rating
stamped on the sidewall of the tire
similar to the
traction, temperature, wear range letters/numbers
The rough 'rule of thumb'
is that if the rolling resistance gets 10% worse
your MPG will go down about 4%
It does not sound like much
but some mudder tread style wide tires are 50% harder to roll
and MPG can go down by 20%
and if the tire lifts the truck or sticks out of the wheel well
it will also cause more wind resistance
Old Dec 28, 2007 | 10:38 AM
RamItOne's Avatar
RamItOne
Guess nitto wont be selling as many 325/60 R 20s[sm=boohoo.gif]
Old Dec 28, 2007 | 11:02 AM
minex's Avatar
minex
I got a 3" lift with 33" tires on my 2nd generation Dodge Ram 1500. Not only did it reduce my gas mileage, but I actually got worse mileage doing highway driving than city driving. I got about 12 MPG in the city and around 11 MPG on the highway cruising at around 65MPH.
Old Dec 28, 2007 | 12:44 PM
SLCHemi's Avatar
SLCHemi
Same story for me as everyone else, bigger rubber equals less mileage and often a reduction in your "butt dyno" response as you've changed your effective gear ratio. When went to a larger tires (from the factory 31's to 34's) I had already ordered the new gears before I even picked out the wheels / tires. But there was maybe a week after I had the tires put on with the stock gears (while I waited for the gears) and I was shocked at how different the truck felt. Seemed like it was working much harder....re-geared and got it back and then some
I've got several "oil burner" buddies who say the same thing happens to them. Their fuel mileage drops a bit, but they don't notice in the power department as much because the diesels have so much torque...
