Anyone have a PIC of an LSD gearset?
I've read the post about how to check, but the wheels are off and the diff cover is off. My build sheet says I have the Anti spin differential, but after reading Osteodoc08's post on servicing, I think my gears look like his. So if anyone has an LSD pic for comparison, I'd appreciate it. I'll be going back under the truck later this morning. I'll get a pic of what I have. Oteodoc08's pic should be below.
[IMG]local://upfiles/38905/40A8D5106C864A2390CC15179B9EC023.jpg[/IMG]
If I remember right that won't help him. Ours are not setup like that. I believe it looks like regularspider gears with clutches to the sides or them. If that makes any sense.
Someone correct me if I'm wrong.
Thanks Nick, that explains everything. I didn't have my camera, but I did look and I do have the clutches. After I got the brakes changed and the wheels back onI double checked and both wheels turned the same direction off the ground. With one down, it was very hard to turn the other. I also found some metal stuck to the magnet. Looks like the PO had C Clip issues. Looked like new fluid in there too, let's hope that this is the end of its problems.
Thanks for all the help,
John
John
