Largest wheel/tire combo
Old Dec 29, 2007 | 11:03 AM
canada4x4's Avatar
canada4x4
Default Largest wheel/tire combo
who has the largest wheel and tire combo ona leveling kit.
give us your specs.
tell us how much rubbing your getting.
how big is to big
Old Dec 29, 2007 | 11:13 AM
bltp203's Avatar
bltp203
Default RE: Largest wheel/tire combo
35's on 17X9.........but mine is a 2500. When I see that combo on a 1500 with just a leveling kit, IMO I think its too big.
Old Dec 30, 2007 | 07:52 PM
canada4x4's Avatar
canada4x4
how about 35x12.5 on 16x8
with justtorsion keys
on my 1500
Old Dec 30, 2007 | 08:41 PM
MoparRob's Avatar
MoparRob
Not positive but pretty sure the SMALLEST rim you can go is 17" due to the rotors.. Might want to check on that. As for 35s depending on your backspacing yes you can fit them with a leveling kit on 1500. Also most people on here say not to go over 35s on a 1500 due to the weakness of the IFS.
muddingking's Avatar
muddingking
Hey i was told i can put 35's on 20's with the 2" level kit and it will be fine cause stock it runs 33" tires, mind you i got a 07 it might be diff not sure
Old Dec 30, 2007 | 10:01 PM
canada4x4's Avatar
canada4x4
your right 17
Old Dec 31, 2007 | 12:32 PM
tdmopar59's Avatar
tdmopar59
if you fit them its not gonna have much flex for anything off road.. i wouldnt reccomend it... i would say 33x12.5's on some 17's would be a better combo....
Old Dec 31, 2007 | 04:07 PM
Mattcmdr's Avatar
Mattcmdr
hey mopar rob what levening kit are u running?
Old Dec 31, 2007 | 08:48 PM
Ram4wd's Avatar
Ram4wd
I have 35X12.50/18's on my 2006 Regular Cab 1500 with a 2" Tough Country leveling kit. But, that is how it came when I bought it used. I have been off-road, albeit not extreme, and not had any issues. However, the 35's are tucked in pretty tight, particularly towards the rear of the front wheel wells. I have also read that typically 33's are the largest recommended on 1/2 ton trucks with IFS front ends.
Old Jan 5, 2008 | 09:59 AM
muddingking
quick ? i have always ran small rims with big tires cause i wanted that sidewall traction now i can honestly say i dont understand why i would loose flex just by going with a bigger rim then a smaller rim a 35 should be a 35 just less side wall, now dont laugh at me i know its a dumb ? but i would rather ask, now if i loose a lot of flex i got my eye on a skyjacker kit
