Brake Rotor Help!
Is there a how to guide on replacing the rear brake rotors on my 04 Ram 1500 2 wheel drive, I did the front no problem but the rear doesn't want to come loose with just the wheel and calipar off, is there a cotter pin or something I'm missing?
thanks
thanks
Yep, there's only two caliper slide bolts.
The ones with the little rubber gators on them.
Take those off and give both the rotor and the top/bottom of the caliper adaptor, sharp repeatedtaps with a small hammer.
Road dirt/pad debris etc, cause the calipers to stick.
Dislodge this debris and wiggle/pull off the calipers.
Hope this helps?
Al.
PS Happy New Year to everyone on the forum!
Hope this helps?
Al.
