07 Dodge Ram: Seatbelt Notification
Old Jan 2, 2008 | 12:52 AM
judlicht's Avatar
judlicht
Default 07 Dodge Ram: Seatbelt Notification
I would like to know if there is a way to disable the unlatched seatbelt notifier in my new 07 Ram. Also, is there a way to have all the door locks unlock when the truck is put into park? Any help is greatly appreciated. Thanks.
Old Jan 2, 2008 | 08:53 AM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: 07 Dodge Ram: Seatbelt Notification
Directions for the belt is in the owners manual.
Old Jan 2, 2008 | 09:50 AM
mbrady8's Avatar
mbrady8
Don't know about the seat belt part but on the doors unlocking. You can program your locks so they dont lock at speed or the all unlock when one door is open. I changed mine so that when one door unlocks they all unlock. Heres the page in the manual....
Auto Unlock On Exit — If Equipped
This feature unlocks all of the doors of the vehicle when
any door is opened. This will occur only after the vehicle
has been shifted into the Park position after the vehicle
has been driven (shifted out of Park and all doors closed).
This feature will not operate if there is any manual
operation of the power door locks (Lock or Unlock).
Auto Unlock On Exit Programming — If Equipped
Customer Programming sequence to enable or disable
the Auto Unlock Feature:
1. Enter your vehicle and close all doors.
2. Fasten your seat belt (fastening the seat belt will cancel
any chimes that may be confusing during this programming
procedure).
3. Insert the key into the ignition
4. Within 15 seconds, cycle the key from the LOCK
position to the ON/RUN position a minimum of four
times ending in the LOCK position
(do not start the
engine)
5. Within 30 seconds, press the driver’s door lock switch
in the UNLOCK direction.
6. A single chime will sound to indicate the feature has
been changed.
7. Repeat the above steps to alternate the availability of
this feature.
8. If a chime is not heard, program mode was canceled
before the feature could be changed. If necessary repeat
the above procedure.
mfs212's Avatar
mfs212
Do you know of a place where I can download my owners manual?
Old Jan 2, 2008 | 10:06 AM
bwhite757's Avatar
bwhite757
The manuals can be downloaded here.
For the Seat Belt Notification:
Old Jan 2, 2008 | 10:08 AM
mbrady8's Avatar
mbrady8
I believe I downloaded it from dodges website... http://www.dodge.com/en/owners/manua...00%20%28Gas%29
Old Jan 2, 2008 | 10:12 AM
mfs212's Avatar
mfs212
Thanks guys....this dinging is really annoying.... Like when I am going to the drive through and need to pull out my wallet.
Old Jan 2, 2008 | 10:13 AM
mfs212's Avatar
mfs212
This will work on my 04 too?
Old Jan 2, 2008 | 10:19 AM
bwhite757's Avatar
bwhite757
That came out of the 07 manual. So couldn't tell you if it works for the 04 or not..
Old Jan 2, 2008 | 10:32 AM
mfs212's Avatar
mfs212
Just looked at the 04 manual and the steps are the same.
