Won't rev above 4000rpm!!!
Old Aug 31, 2017 | 12:53 AM
  #21
Gary Logan (SuperGlueNinja)'s Avatar
Originally Posted by 04Ram1500Spali
Did you ever find out what was wrong?? I'm experiencing this too now. It seems it may be something in the valve body like the governor solenoid.
I did actually. I changed both the crank sensor and the can sensor on bank 2 which one was the culprit I'm not certain of since they communicate with each other I just changed both. Fixed the problem.
Old Aug 31, 2017 | 01:26 AM
  #22
04Ram1500Spali's Avatar
04Ram1500Spali
Awesome, I'll look in that direction too then.
Old Jan 2, 2019 | 05:35 PM
  #23
Antonio Alba's Avatar
Antonio Alba
Default 2011 Dodge Charger v6
My car wouldn’t go pass 4000rpms. Nd my Car ended up started to make a small ticking sound Nd it got worse Nd I checked Nd I had almost no oil :/ well I ended up adding oil Nd it’s fine now 🤙🏼🤙🏼🤙🏼🤙🏼
