Erratic Idle- 04 Ram
Old Jan 6, 2008 | 01:15 PM
MorsePower's Avatar
MorsePower
Default Erratic Idle- 04 Ram
My 04' Ram has been acting up in the cold weather of CNY. It has an idle problem under 40 Degrees F. It has stalled a couple of times on me driving at a low idle. It seems like there is a flat spot in my accelerator. I would have thought it was only some bad gas but it doesn't happen any other time of the year and it's the second year in a row with this problem. Any help would be appreciated.
Old Jan 6, 2008 | 03:31 PM
hemiyellow's Avatar
hemiyellow
DC Insider
Default RE: Erratic Idle- 04 Ram
is it a 4.7, 5.7?.....only thing i see for 5.7 is a TSB for replacing the throttle body but condtions the issue occurs is below 0 that TSB number is 14-002-05......you may want to pull the throttle body off and give it a good cleaning and then see what happens
