02 Ram locked in security mode
Old Jan 9, 2008 | 09:48 PM
neyc20's Avatar
neyc20
Default 02 Ram locked in security mode
I've found useful info in the past on DF thought i'd try again with my latest issue.
I have a 2002 Ram 1500 pickup thatI believe is locked in security mode.
Nothing happens at all when I try to start it. No ignition, headlights, dome lights,windows,locks,etc.The only sign of life is the red flashingdash light.
I've tried disconnecting the battery fora couple hours-no change. I've tried charging the battery-no change.
I'm toldessentially my key and my truck aren't communicating. Any thoughts, tips, tricksor is this a dealer only fix.
Thanks for any help on this!
Old Jan 9, 2008 | 10:01 PM
Dodge Tech's Avatar
Dodge Tech
Default RE: 02 Ram locked in security mode
lets see if i get this stright no start no headlights,windows door locks correct? and as for as the key U must have a gray key yes?
well who ever u took it to has not got a single clue to how an alarm system works. It will only shut off the fuel or starter kill windows and everything else is not part of it. If u have an new style 1500 I would look tward the Fuse box or front controler have it scanned unless u like spending money and guessing.
Old Jan 9, 2008 | 10:05 PM
CarGuyOhio's Avatar
CarGuyOhio
I had an 89 IROC that did the same thing. Turned out a wire had broken in the ingition switch that ran to the sensor to check the resistance in the key to disable the "security lock". On my IROC it was two very small yellow wires exiting the column. I spliced in the chip on my other key at the bottom and it started right up. Unfortunatly the chip is not exposed on the Dodge key and I do not know what color wires are used in this application.
Old Jan 9, 2008 | 10:27 PM
neyc20's Avatar
neyc20
Thanks for the reply. Yes gray key. I'll check fuses. If not sounds like a trip on the hook to the dealer. Thanks for the insight.
