Best exhaust?
Old Feb 5, 2008 | 05:46 PM
  #21
thekingcole2003's Avatar
thekingcole2003
Default RE: Best exhaust?
does anyone know the best way to do the flowmaster on a 2006 3.7l v6? should i run single, dual, or dump the exhaust right underneith the truck? and how many cats do i need to leave on. i dont want it to sound like **** and crackle and pop like an import i just want a grumble.. anyone???
Old Feb 6, 2008 | 09:56 PM
  #22
cramerica's Avatar
cramerica
I have the Flow 40 on my 3.7 Dak...and I love the sound...noteven thatricey at higher revs, and if it's under a little load, you avoid that raspy sound. Winding up in 3rd coming onto the freeway always sounds good, anda sub-2000 RPM pull up a hill at low speed sounds like an old glasspack V8. Luckily 3.7 is enough displacement for a little rumble. Do 4.7's and Hemi's sound better, sure...but for a $70 muffler on a V6 the 40 gets my vote.
As for the setup, I have all the resonators cut out and the muffler output turned down right before the rear axle. It saved alot of time and money to have the Monroe guy do that, as opposed to running pipe up and over the axle, and it helps the sound resonate a little bit. The trade off is a little extra in-cab noise. I'm sure rear or side outputs would wake up other drivers better, but I still manage set off the occasional car alarm with my exhaust
Old Feb 7, 2008 | 11:05 PM
  #23
rfry's Avatar
rfry
i have a magna flow with the tail pipe dumping just behind the rear differential and that has worked out for me
Old Feb 23, 2008 | 11:50 PM
  #24
babyblackram's Avatar
babyblackram
i hadtwo aero turbine on my hemi i traded in on this one and i really love them. so as soon as i hear them on a v-6 i will probably go with them again at2525 true duals
Old Feb 25, 2008 | 12:08 PM
  #25
XxSilentHawk99xX's Avatar
XxSilentHawk99xX
I have the flowmaster super 40 exhaust on mine....SIDO....It makes a great sound at low rev's but once you get higher it starts sounding overly whiny
