Build Sheet Question
Old Jan 10, 2008 | 01:17 PM
indyctdgrl's Avatar
indyctdgrl
Default Build Sheet Question
Thanks to the posts on this forum I was able to request a copy of the build sheet for the truck we recently purchased and received the information earlier this week.
Hopefully someone can answer my question.We found a discrepancy between what was listed on the build sheet, compared to the window sticker and truck as received. It's not much, but with fuel prices the way the are, every $ counts! The build sheet states that the truck was shipped with front and rear floor mats. The window sticker does not list it as an option and the truck was not delivered with them. Shouldn't whats stated on the build sheet be what's received?
Old Jan 10, 2008 | 04:54 PM
chongo's Avatar
chongo
Default RE: Build Sheet Question
I would think so - call your salesman and get your mats - if your dealership is worth anything they will get you a set.
Old Jan 10, 2008 | 05:33 PM
HammerZ71's Avatar
HammerZ71
ORIGINAL: chongo
+1 Anything on the build sheet was provided when your vehicle was delivered to the dealer. The dealer probably removes them and then sells them separately. I would go see the sales person or manager and bring a copy of the build sheet with me.
Old Jan 10, 2008 | 06:31 PM
Mattcmdr's Avatar
Mattcmdr
where did u get the build sheet from???
Old Jan 10, 2008 | 06:41 PM
hemiyellow's Avatar
hemiyellow
DC Insider
you can get a build sheet from the dodge website, and then click on "For Owners" and then "Customer Assistance" ....or you can ask someone that has access to dealerconnect and have them get you one....like me lol
Old Jan 10, 2008 | 08:38 PM
MoparMan61L's Avatar
MoparMan61L
Floor mats no longer come standard on any Dodge trucks. If they are not listed in the optional equipment section on the window sticker the truck should not have them. I don't know what the build sheet is referring to but I have seen the factory call the actual carpeting floor mats before. I think all vehicles should come with floor mats but Chrysler is getting stingy. If you want to e-mail me the VIN I can look it up for you.
Old Jan 10, 2008 | 11:36 PM
indyctdgrl's Avatar
indyctdgrl
Thanks to all for your responses.
MoparMan61L, I thought that might be the case as well, but it spells it out as Front & Rear Floor Mats and carpet is listed above the carpet item. I've sent you an email with the VIN.
Below is the Build Sheet info/email sent by Chrysler Customer Assistance:
Thank you for contacting the Chrysler Customer Assistance Center regarding your 2007 Dodge Ram.
As per our records, your vehicle was equipped from the factory with the following:
Cloth 40/20/40 Prem Bench Seat
Med Slate Gray
Light Group
Protection Group
Trailer Tow Group
Quad Cab Big Horn Value Group
Monotone Paint
Single Rear Wheel Group
136 Amp Alternator
750 Amp Maintenance Free Battery
Anti-Lock 4-Wheel Disc Brakes
40/20/40 Split Bench Seat
Front Height Adjust Shoulder Belts
Next Gen Multistage Front Air Bags**
Front Seat Area Carpet
Passenger Assist Handle
Rear 60/40 Split Folding Seat
Rear Underseat Compartment Storage
Mini Floor Console
Overhead Console w/Trip Computer
Front Center Seat Cushion Storage
All 4-Speed Automatic Transmissions
4-Spd. Automatic 48RE Transmission
Man Shift-on-the-Fly Transfer Case
5,200# Front Axle
3.73 Axle Ratio
11.50 Rear Axle
Anti-Spin Differential Rear Axle
5.9L HO Cummins Turbo Diesel Engine
Tinted Glass Windows
Rear Power Sliding Window
Sun Visors w/Illum Vanity Mirrors
Rear View Auto Dim Mirror
Passenger Side Sun Visor w/Mirror
Power Heated Mirrors, Fold-Away
All Vehicles W/Power Mirrors
Remote Keyless Entry
Sentry Key Theft Deterrent System
Air Conditioning
Dash Liner Insulation
Floor Tunnel Insulation
Instrument Cluster w/Tach
Instr. Panel Color Keyed Bezel
120 MPH Primary Speedometer
Var Intermittent Windshield Wipers
Cigar Lighter
Dual Note Electric Horns
12V Auxiliary Power Outlet
Power Locks
Power Windows, Driver One-Touch
Power 6-Way Driver Seat
STRIPE/BADGE/MOLDING/COLOR
Glove Box Lamp
Ash Tray Lamp
Front Dome w/On/Off Switch Lamp
Underhood Lamp
Halogen Headlamps
Fog Lamps
Cargo Lamp
Bright Rear Bumper
Body Color Upper Fascia
Bright Front Bumper
Front License Plate Bracket
Bright Grille
Ram's Head Badge
Black Windshield Moldings
SLT Badge
4X4 Badge
Removable Tailgate w/Caliper Latches
Front Air Dam
Bighorn Badge
Federal Emissions
34 Gallon Fuel Tank
Auxiliary Transmission Oil Cooler
Speed Control
Electronically Controlled Throttle
Heavy Duty Engine Cooling
Current Generation Eng Controller
Bright Silver Metallic Clear Coat
All Radio Equipped Vehicles
4 Speakers
Fixed Long Mast Antenna
AM/FM Compact Disc Radio
Sirius Satellite Radio
Power Steering
Leather Wrapped Steering Wheel
Front Heavy Duty Shock Absorbers
Rear Heavy Duty Shock Absorbers
Front Stabilizer Bar
Tilt Steering Column
Full Size Spare Tire
Tire Carrier Winch
LT265/70R17E BSW All Season Tires
Michelin Brand Tires
17" Steel Spare Wheel
17X8.0 Forged Aluminum Wheels
All Aluminum Wheels
Center Hub
Non Adjustable Pedals
Pickup Box
Toluca Painted Cargo Box
Tow Hooks
Transfer Case Skid Plate Shield
Class IV Receiver Hitch
7 Pin Wiring Harness
Trailer Tow w/4-Pin Connector Wiring
YES Essentials(R) Seat Fabric
For More Info, Call 888-539-7474
1-Year Service Provided by SIRIUS
Build To U S Market Specifications
5.5 Additional Gallons of Diesel
Spring - Left Front
Spring - Left Rear
Spring - Right Front
Spring - Right Rear
Four Wheel Drive (4WD)/(4X4)
6 1/2 FT. Cargo Box
Quad Cab
Old Jan 11, 2008 | 06:40 PM
MoparMan61L
I checked on Dealerconnect and StarParts and your truck shows to have come with option code CLE which is a set of 4 floor mats for a quad cab in trim code D5 part #1GR041DHAA but it also shows this message For 2007 model year, floor mats are a stand alone option. The mats are not included with any packages. If you receive a vehicle that is not equipped with floor mats, do not submit a "Shortage in Error" warranty claim unless the vehicle was ordered with floor mats as an option.) This is conflicting because the code CLE is listed under standard equip for your truck and the message states they are optional. Does your window sticker list the mats in the standard equipment section?
Old Jan 11, 2008 | 07:56 PM
indyctdgrl's Avatar
indyctdgrl
Thanks for checking on this info for me!!
That's why I stated in my original postthat I was confused. Not listed on the window sticker, but listed on the build sheet. What they've stated is definitelycontradicting... [sm=confused06.gif]Suggestions?
Another question... who prints the window stickers? Do they come from the factory with the truck or does the dealership print them? The dealership we purchased the truck from purchased two other dealerships and this truck was likely from that purchase. Is it something that might have gotten mixed up when adding the additional inventory possibly? (Maybe just wishful thinking here...) Just not sure how to proceed, if at all...
Old Jan 11, 2008 | 08:44 PM
MoparMan61L
The window sticker comes with the vehicle. If I were you I would show the dealership the information you have and see if they will give you the floor mat set. If you came into my dealership with that information I would give them to you, but as you know every dealershipis different. According to the information I have available you should have gotten a set of floor mats.
