Electronic Throttle Control (ETC)
Old Jan 16, 2008 | 07:30 AM
Canadian Ram's Avatar
Canadian Ram
Default Electronic Throttle Control (ETC)
Hi everyone, I'm new to the forum and had a problem this morning I wondered if anyone else has encountered. Its cold where I live right now (-15 to -20 celcius)and this morning, I started my truck to let it warm up. I went back into the house to grab a coffee, and when I came back out 15min later, the truck had stalled and the "Electronic Throttle Control" light was flashing. I restared the truck, and drove the 100km to work. The light stayed off, and I drove the at different speeds, hard acceleration, cruise control etc. It wasn't ideling rough and didn't seem to hesitate or be low on power. It is cold here, but it has been way colder before and the light has never come on so I don't think it has anything to do with the temperature.
It is a 2004 Ram 1500 QC 4X4 with the 5.7L Hemi. I have no mods done to the truck and it has 140000km.
If anyone else has had a problem with the "ETC" please shed some light on this and what the fix was. Any help would be appreciated.
I have been reading the forum for awhile now and there is definatley a wealth of knowledge and good advice here.
Thanks again.
Canadian Ram
Old Jan 16, 2008 | 07:58 AM
abarmby's Avatar
abarmby
Default RE: Electronic Throttle Control (ETC)
Computer gremlin?????
Old Jan 16, 2008 | 09:30 AM
Parts/Service's Avatar
Parts/Service
There is a TSB that sorta address the issue you are having. TSB # 14-002-05. Here is part of the description....
SUBJECT:
InactiveThrottle Body In Cold Ambient Temperatures
OVERVIEW:
This bulletin involves replacing the throttle body.
MODELS:
2003 - 2005 (DR) Ram Truck
NOTE: This Bulletin Applies To Vehicles Equipped With 5.7L Engines (Sales Code
EZA).
SYMPTOM/CONDITION:
Customers may experience any of the following Electronic Throttle Control (ETC) system
symptoms at start up in extreme cold ambient temperatures (Below 0° F (minus 18°C)):
Partial Return From Cold Start Fast Idle
No RPM Increase When Accelerator Pedal Is Moved
Diagnostic Trouble Code 2110 - Throttle Actuator Control System - Forced Limited
RPM
Diagnostic Trouble Code 2118 - Throttle Actuator Control Motor - Current
Range/Performance
DIAGNOSIS:
If a customer indicates that they have experienced the condition, perform the Repair
And a full view of it here >>>>> http://dodgeram.info/tsb/2005/14-002-05.htm
Old Jan 16, 2008 | 09:37 AM
Canadian Ram
Thanks very much.
I will look into this.
