anyone know an easy way?
Old Jan 19, 2008 | 07:17 AM
Mopar2511's Avatar
Mopar2511
Default anyone know an easy way?
I just bought some off road lights and it came with the switch to go inside the cab. im trying to get the wires into the cab. i installed some cab clearance lights myself and already have a switch for that i had to drill a hole in a plastic liner thats up above the pedals and steering column. does anyone know how i can run these wires into my cab? preferably without drilling.its a 2004 SLT. Thanks in advance
Old Jan 19, 2008 | 10:35 AM
tdmopar59's Avatar
tdmopar59
Default RE: anyone know an easy way?
hmm... did you check all the area's of the firewall for like a gromet you could shove it through.... if not your gonna have to drill it and if you are worried about leaks use a grommet to seal it off..
Old Jan 19, 2008 | 11:34 AM
hemiyellow's Avatar
hemiyellow
DC Insider
theres a coupld gromets you could use....the one i always used is the one on the driver side where the wiring harness is going into the cab....use poke a hole in it, get your switch wired up and then seal the hole with some RTV or something like that
Old Jan 19, 2008 | 12:02 PM
dieseldoc1's Avatar
dieseldoc1
i had a lot of wires to run and cb coax so i removed the cover where the clutch would bolt up to the firewall the duct taped over the hole to keep dust out.
