Bigger tires on stock 17 in rims
Old Jan 20, 2008 | 09:58 PM
alegav's Avatar
alegav
Default Bigger tires on stock 17 in rims
I am looking at getting my truck lifted pretty soon and was curios to know if i could run a bigger tire on the stock rims? I would like to go with a 315/70/r17 but i am not sure if this is possible due to the rim width and backspacing, any help would be much appreciated.
Thank you.
Old Jan 20, 2008 | 10:45 PM
MikeHTally's Avatar
MikeHTally
Default RE: Bigger tires on stock 17 in rims
You don't say what year, but the stockers on my '03 were 17x8, probably with 0 offset. Not sure about the backspace... guessing it'll be in the 4 1/2" range. A 315/70 may be OK with an 8" rim width, but that may be the low end of the compatibility range. That overall diameter is a good bit bigger than stock. What rearend does it have? You may take a sizable hit on final ratio.
Old Jan 20, 2008 | 11:23 PM
oefootball_70's Avatar
oefootball_70
I have 34 inch tires on my stockers.
Old Jan 21, 2008 | 01:12 AM
alegav's Avatar
alegav
Its a 2003. I have the steel looking rims. I cant seem to find the specs on em
