Squeak when i floor it!!! (& Wobble)
Old Jan 24, 2008 | 02:46 PM
djmarshall85's Avatar
djmarshall85
Default Squeak when i floor it!!! (& Wobble)
Hi Guys,
Was giving a friend a run for his money last night and noticed that when i floor the ram it has a squeak/squeal for a split second. It only happens when its at high revs and for a very short time, sounds like it might becoming from the engine but difficult to pin point. Seems to be on the kick down.Has anybody got ideas as to what it might be? Have checked belts and all seem tight!
Also have a wobble on the steering wheel but only at low speeds (30-40mph) steering holds steady at 70mph. Have done a search and seen about the death wobble but that appears to be at high speeds. Am going to try switching the front tyres to back and see if that helps, can't see any bulges or tread lifting on the tyres (they arestock goodyear and have read that there not the best). So if you have any suggestions then i would be very grateful?
Thanks for your help
David
