3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
yea get a programmer then you can adjustyour sift points an you will be happy with the results
+1
I have the superchips flashpaq. I set my shift points at 5800, redline at 6200. I didnt see any benefit of goinghigher since the motor stops making power after that.
Also with the tuner you can set different tunes like performance, towing and economy. I have mine on performance and I love it. Helped a lot with throttle response and my MPG has been going up ever since I installed it 4 days ago.
sct has some great work... they are really popular in the ford world... check them out though they are working on the hemi applications as well though!@
I have the same truck as you and I have the superchips 3715. I like it, can't set shift points but you can give it different tunes, and raise the rev limiter and speed limiter. I have removed the speed limiter, but never messed with the rev limiter since its there for a reason.
