Something is leaking
Old Jan 28, 2008 | 12:36 AM
gheegrose's Avatar
gheegrose
Default Something is leaking
As I was under my Ram today changing the oil, I noticed something was leaking. I'm not a pro at mechanics, and didn't take a whole lot of time trying to figure it out. Does this look familiar to anybody? [&:]
The pictures were taken from underneath the drivers side, just behind the front tire, looking toward the front of the truck and then looking up at the leak.
[IMG]local://upfiles/82353/8169CD24EC6041FA8638590F446C65AD.jpg[/IMG]
[IMG]local://upfiles/82353/17DDEDA6E0F34E24A32E00182782CBD1.jpg[/IMG]
Old Jan 28, 2008 | 12:38 AM
gheegrose's Avatar
gheegrose
Default RE: Something is leaking
Another
[IMG]local://upfiles/82353/26207BA521F54C8BBB29B1E0FB6803EE.jpg[/IMG]
Old Jan 28, 2008 | 12:43 AM
Redram05baby's Avatar
Redram05baby
Check Your Power Steering Level.. Lots of Those Issues In Early 3rd Gens
Old Jan 28, 2008 | 07:20 AM
MikeHTally's Avatar
MikeHTally
The red tint would indicate ATF +4 tranny fluid. The location would indicate it's coming from the power steering. Exactly where it's hard to say, but with all the discussion of poor hose fittings, I'd guess one of the hose connections is leaking.
Old Jan 28, 2008 | 09:22 AM
gheegrose's Avatar
gheegrose
Thanks guys. I will give it a closer look.
Old Jan 28, 2008 | 09:49 AM
mfs212's Avatar
mfs212
Yea...definitly power steering... They used some really crappy clips on our trucks. Usually the problem can be fixed for like $1.
Old Jan 28, 2008 | 09:52 AM
2005cobrakiller's Avatar
2005cobrakiller
i replaced the power steering pump 3 times on my 05 and im about to do it again..... its prolly the connections on your return line..... or it could just be the pump leaking. On your pwr steering pump there is a piston this is known for blowing through the cast wall of the pump.....replacing the pump only takes 15 mins or so.....good luck
Old Jan 28, 2008 | 09:53 AM
Pyro's Avatar
Pyro
I Beat Tetris
Mine is doing the same thing, I'll be dropping into autozone later today for a $1.99 bottle of fluid
Old Jan 29, 2008 | 12:39 AM
gheegrose's Avatar
gheegrose
Yup, you guys were right... power steering fluid was low. I added more and will check those connectors when I get back home.
