Anybody using one of these?
Old Jan 29, 2008 | 10:50 PM
proqual's Avatar
proqual
Default RE: Anybody using one of these?
I am old fashion and for what (or any) value it may have the trouble it may cause would be a disaster. The bolt is tried and true not to give any problems. If you look in the owners manual it gives torque values for almost all items on the vehicle. If you are concerned about stripping the pan, use a torque wrench and torque to factory specifications. Good luck on your decision.
Old Jan 29, 2008 | 11:18 PM
JD1500's Avatar
JD1500
Well, it has never been an issue on our combines, or my cat, wich is always in the dirt/dust/grime. bumps tall nasty weeds, etc, etc.
I have never seen, or heard of one of these accidentaly opening. I think if you hit one hard enough to knock it open, you would have other major problems, like a dented case, broken pan.
On ours, you have to push up, or down while, moving the valve, i dont think you could accidentaly open it by rattles/soft impact
Old Jan 30, 2008 | 01:59 AM
Andrew S's Avatar
Andrew S
Fixing a stripped hole isn't really that difficult. Definitely not difficult enough to warrant the use of something like this. If you are that paranoid about stripping holes out buy a torque wrench. It will get much better use and can work on more than one bolt.
Old Jan 30, 2008 | 07:25 PM
NYPANAMA42's Avatar
NYPANAMA42
ORIGINAL: HammerZ71
I think the funny thing about the responses here is that I never knew the thingy existed and it was brought to my attention on one of the off-road forums I'm on, where the little do-dad has attracted quite a following...
Old news....This has been around for a while now. If you check you'll see that Fram had one out about two years now.....
I'm really surprised at you HammerZ, how could you not know about this.......Jeez...........I'm revoking your Dodge pass..
Old Jan 30, 2008 | 07:28 PM
derricksmash's Avatar
derricksmash
V6 Ram Moderator
all of our cars that we've done a coolant flush on have something similar in the drain plug on the block. it was like a 3' pipe, with a little brass fitting on it like that to make it easier for next time.
Old Jan 30, 2008 | 08:27 PM
HammerZ71's Avatar
HammerZ71
ORIGINAL: Andrew S
It's not that I'm paranoid at all, I've never stripped one out in over 20 years of changing oil. But this very hard core off-road forum I'm on had a thread about them, and are now doing a group buy at a good price. Seems a large percentage of the 4x4 crowd, at least on that forum, is using them mainly because of how much more often you need to change your oil when you play in the dirt, mud & dust...
Old Jan 30, 2008 | 10:21 PM
JD1500's Avatar
JD1500
if your getting a good price, i say go for it hammer.
Old Jan 31, 2008 | 08:20 AM
The Peddler's Avatar
The Peddler
I have one on my 68 mustang, and I love it. Have not got one on my truck, yet.
Old Jan 31, 2008 | 08:49 AM
2005cobrakiller's Avatar
2005cobrakiller
I was a hydraulics expert in the military....I have seen too many valve bodies leak man.....if i were to use one I would have to take it apart and see how well its made...... as far as convenience....looks pretty damn good....I would say use it if you dont plan on beating things on your truck....if you drive like me you may want to get a reinforced bolt with a security guard shack lmao....
Old Jan 31, 2008 | 10:02 PM
MikeHTally's Avatar
MikeHTally
I had the Fram unit on my Gen 2. It worked flawlessly for over three years. Forgot about it when I traded. Couldn't find a Fram replacement locally, and online it was as much as the Fumoto. The Fram wasn't quite as easy to use, so I switched.
