pacesetter headers lt's installed
well i got my headers in today an headed out to my shop I'm not really done with them yet i still have toweld the cats back on tomorrow its loud as **** now i did get on it a lil bit. i feel a Lil more power im sure after im done i be able to really feel the change in performancehopefully anyway the only thing i wanted to ask abouton theright sidei can here a leak in it but i put the new gasket on there i torqe the bolts as tight as i could get them ani still herea small leak in there up toward the front of it have yall had any problems like that i know i got it all on there right im just checkingto see if it done anything like this when yall put them on or did i not do something right??
Welcome to the world of headers my friend. I haven't put any on my truck yet, but I had a set of edelbrock headers on my '87 Monte Carlo SS and it was a never ending battle. It is possible that the header itself is not straight, did you check this?
not quite what I am saying, but not a bad idea at all. I'm saying if the header isn't flat where it bolts to the head. You would think quality control would catch it but I have seen it more than once.
The gasket that comes with the Pacesetter headers is cheap garbage. I didn't like it as soon as I saw it, but was in such a hurry to get them on that I used it anyway. I have not had any problems yet, nor can I hear any leaks, but a lot of guys report gasket related issues. The mopar ones are a better material and a lot thicker, so they seal a lot better.
At some point, I intend to replace mine with the mopar one.
http://moesperformance.com/index.php...oducts_id=1144
Trending Topics
ORIGINAL: HammerZ71
I've also found if you tighten the bolts starting from the center and work out it seals better.
A thin coat of red RTV (hi-temp) will also help seal minor flaws in the header or head. Just make sure it says safe for sensors or it could screw up your o2 sensors.
http://www.permatex.com/products/aut...one_Gasket.htm
[IMG]local://upfiles/26683/B2DD3CFF6F1C4BF1A3BAA77AD653557A.jpg[/IMG]
