need advice on tires
Old Jan 30, 2008 | 01:10 PM
stunta666's Avatar
stunta666
Default need advice on tires
I found the rims i want but they only come in 20x8.5, the problem is i want the mickey thompson baja atz radials in a 305/50/20. i talked to the rim dealer and they said they can make it fit but im worried this will cause a problem, they got some 275/60/20 in a nitto terra grappler or toyo open country that will fit fine but i like the mickeys better. which tires would you guys go with?
Old Jan 30, 2008 | 01:17 PM
stanmantx's Avatar
stanmantx
Default RE: need advice on tires
I had the terra grapplers that were 14 inches wide on 10 inch wide rims. Never had a problem and they look pretty sick when they're mounted. I wanted the toyos though. Search my gallery if you want to see the tires. They were mounted on the Blue Brontosaurus.
Old Jan 30, 2008 | 02:05 PM
RaptorRacing's Avatar
RaptorRacing
why not go with the cooper zeon ltz's 305-55-20
Old Jan 30, 2008 | 03:30 PM
tdmopar59's Avatar
tdmopar59
stay away from those nittos... they wear very quickly...
