steering pump
Old Feb 4, 2008 | 03:31 PM
shah 303's Avatar
shah 303
Default steering pump
my steering pump is starting to go out. it will cost 1100 plus labor to replace old one. is there any way to find cheaper. i couldnt afford that kind of money right now. when i press my brakes and turn, the steering gets real hard to turn. it also makes noise when u turning the wheel while not moving
Old Feb 4, 2008 | 03:52 PM
kregier's Avatar
kregier
Default RE: steering pump
First thing I would do is buy some new hose clamps to replace the ones from the factory and then top up the fluid again and see how it goes. It could just be that the leak is so bad it can't build up enough pressure. $5 could save you that $1100. The noise is because it's low on fluid. Check/fill immediately.
Old Feb 4, 2008 | 03:55 PM
mmstar23's Avatar
mmstar23
is it the same noise that when you turn your wheels real hard...that type of sound or no?
Old Feb 4, 2008 | 04:06 PM
shah 303's Avatar
shah 303
i added steering fluid few weeks ago but it seems cant to turn the wheel at all unless you move your truck.
Old Feb 4, 2008 | 04:08 PM
shah 303's Avatar
shah 303
ORIGINAL: kregier
i already took care of that fluid check. it is good.
Old Feb 4, 2008 | 04:17 PM
kregier's Avatar
kregier
If the level is good and it's still making noise, then your pump is probably shot. I can't believe you're going to get charged that much though. A p/s pump should be $150 max. and then about 2 hours labor.
Old Feb 4, 2008 | 07:32 PM
shah 303's Avatar
shah 303
ORIGINAL: kregier
i hate dealership[:@][:@][:@][:@] cuz they love to charge mooooorrrrrrreeeee!!!!!
Old Feb 4, 2008 | 10:09 PM
ce2flaco's Avatar
ce2flaco
SO........why go to the dealership? Get out the phone book and start calling shops for quotes. Or just spend the cash and let the dealership violate you.
Your cash, your choice.
Old Feb 4, 2008 | 10:45 PM
CarGuyOhio's Avatar
CarGuyOhio
I assume you are over 70K miles? It should be covered under the 7/70 powertrainif you are under 70K.
Old Feb 6, 2008 | 03:47 PM
shah 303's Avatar
shah 303
ORIGINAL: 94rt10ohio
i am at 58k miles. steering pump is part of powertrain warrenty? i thought it would be bumper to bumper.
