3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
i've got an 06 ram 1500 4x4 stock now, im looking to get some 20" rims with 305/55/20 mickey baja atz tires. the rims have a +20 offset. will they fit and will they either stick out or sink in too much?
they should be fine. im pretty sure the stock 20s are +19 offset. the +20 ones will sit in a little more but you wont be able to tell its only 1mm dif. i just ordered some wheels todat and they are +18 offset. i also have an 06 qc 4x4.
That's a sizable offset. What's the backspace? I think you'll find the stock offset to be 0, where the mounting surface is on the same plane with the wheel centerline.
I just double checked the factory wheel offset for the 20" wheels. And one said they were 19.05mm and another said 19mm and one site said they were 18mm so either way the offset will be fine
