AWD question
Old Feb 7, 2008 | 07:35 AM
Canadian Ram's Avatar
Canadian Ram
Default AWD question
Quick question in regards to AWD.
I have a 04 5.7 QC 4x4 with the AWD. My question is that does anyone know how this system works? Does itengage and disengage the front tires or is it always "on"? What changes when I switch it to 4HI? Sometimes when I accelerate on ice, the back end will slide out like a 2WD would and other times the truck hooks up on the ice like its in 4HI.
I don't have any problems with it, just a curiosity thing I guess.
Old Feb 7, 2008 | 11:08 AM
Canadian Ram
Default RE: AWD question
bump, any thoughts?
Old Feb 7, 2008 | 11:34 AM
John  M's Avatar
John M
If I recall correctly, switching to 4hi simply locks the center differential. The normal AWD allows some "give" so you can turn without binding.
Old Feb 7, 2008 | 11:38 AM
josh213corbs's Avatar
josh213corbs
That sounds right to me John M...
While we're asking curious question, then, does anyone know if there's a particular speed recommended to stay under when switching into 4WD?
Generally I've never switched when I'm going more than 40mph, but does this matter? Any thoughts?
Old Feb 7, 2008 | 12:03 PM
Canadian Ram
I've always thougth that as long as the front tires weren't spinning at a different speed than the back ones, you could do it up until 80kph (50mph).
Thanks for the info on AWD
Old Feb 7, 2008 | 09:32 PM
D917's Avatar
D917
I had a question about this also.
The *** on my Ram is set to AWD. Does this meanthe Ram is All Wheel-Drive all the time? Is it even possible to drive in 2WD?
