Update on Blueish white smoke
[:@][:@]Well I want to see if there is in fact a leak on my truck so i parked it in my garage last night..when i woke up this AM i started the truck and no smoke and when i got on the gas no smoke just your normal from it being chilly in the morning but thats it when i pulled it out of the garage i notice a pinkish red liquid on the floor,,,So now i think my truck is leaking transmission fluid or coolant cant determine which it is.On further inspection i notice where the drive shaft meets the tranny it nice and clean and wet so i think that is where it is coming from DOES ANYONE KNOW WHAT THIS COULD BE THERE ARE NO PROBLEMS IN SHIFTING AND THE COOLANT RES. IS FULL PLEASE HELP SO I CAN CORRECT THIS BEFORE ANY MAJOR PROBLEMS OCCURR...THANKS FOR ALL OF YOUR GUYS HELP[:@][:@]
First, Your post said Bluish white smoke.... usualy that is an indication of burning oil. (i.e. piston ring is bad, ect.) The red stuff on the ground... Feel it, coolant will feel just like water and act like water. Tranny fluid is hydro fluid. It is an oil, and will act nothing like water. You will touch it and you can smear it all over your finger and feeloily. Also, how big is the "spot" of liquid on the floor?
Coolant will not pull fluid from the res until the engine is hot, and the water is flowing. Means it may take a few miles before you will see the res go down.
Tranny will show full, even when it is dangerously low, if the vehicle has NOT been running. You need to start the vehicle, put it in each gear for atleast 10 seconds, then in Neutral. Then check the fluid. This will tell you if your really low or not. ALSO, get under the truck and feel the "clean and wet" spot behind the tranny. find out what type of fluid it is. (probabily tranny). Remember that the amount of oil in that area doesn't directly relate to the amount of fluid lost. Meaning that if it is tranny fluid, that very little can cover a large space.
I'd check the tranny, and keep looking forbluish smoke. Just watch your fluids, and keep an eye out for any other symptoms.
Welli havent noticed the smoke anymore and i havent before yesterday and i spoke with my mech. has said my gasket and bearing are gone where the u joint meets the tranny.he also said that 350.00$ and three hours will do the trick but i dont know i will shop around for prices all i know is that i want to do as much to prevent and more damage to my truck.
ORIGINAL: RaptorRacing
Either way, the leak should not cause any harm. Check your tranny fluid every few days, maybe once or twice a week. as long as it is full you shold be fine for a while.
Good luck.
My dads power steering fluid was red from the factoy in is 03 ram 2500. I saw red fluid on the ground and thought it was tranny fluid and then saw it was the power steering pump.
Trending Topics
ORIGINAL: sschevy400
