3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
thanx!! how hard would it be to install this in my driveway?? do I need any special tools?? as long as there is no shims or adjusting and it's just a bolt in, I could do it....
It All Depends.. MyDetroit Install Required noAdditional Shims.. Yet My Jeepstru trac & OX RequiredA Different Shim Set Up. If Your Daring Enough, Keep All The Stock Shims - Install The LSD Then Test Your Mesh/ Backlash. Downside: If It's Not Right, You'll Have to Find Someone To Come To Your Location To Fix It.
My Advice to You Fellow 4.7 - Upgrade Your Gears While Your At It. That Will Require A Professional Install.
Got it......I think for now I'll go with a LSD in the rear and go from there....I checked out tire prices for my stock 20' and they're RIDICULISLY expensive!! If i'd known that I wouldn't have opted for um.....oh well, they still look good...
