Mega Cab 1500 vs 2500
Old Feb 13, 2008 | 06:28 PM
Timmerduder's Avatar
Timmerduder
Default Mega Cab 1500 vs 2500
So is there any?
I did the Dodge website "build" 2 exact trucks though the 2500 did have a few more options that I could choose but did not (like the no-gasser motor) to make them exactly like mine and found the 1500 to be almost a couple grand less but no difference in anything....
They must have cheapened em up somehow?
Old Feb 13, 2008 | 06:37 PM
JD1500's Avatar
JD1500
Default RE: Mega Cab 1500 vs 2500
I thought the 2500 had a different suspension setup. i know the 15 and 25 are both solid, but i though the 2500 was set up differently...
Old Feb 13, 2008 | 07:36 PM
oefootball_70's Avatar
oefootball_70
ORIGINAL: JD1500
hmm.... I though the only difference was the numbers. Maybe I'm wrong.
Old Feb 13, 2008 | 07:53 PM
JD1500's Avatar
JD1500
that is what i thought at first too. But then it was discussed on here that the rear was different, the payload and tow capacity of the 1500 were lower than a 2500, and this was why.
BUT, that also could be dodge just printing that, trying to save the sales of the 2500's
Old Feb 14, 2008 | 03:54 AM
RamItOne's Avatar
RamItOne
Thought the mega cab was built on a 2500 frame. thats why those big bumpers like from ranchhand will only fit on 2500-3500 as well as a 1500megacab only. maybe the leafs are less on the megacab dont know.
Old Feb 14, 2008 | 08:24 AM
Drew's Avatar
Drew
I believe the suspension is a little stiffer on the 2500, past that the only difference is the door sticker stating payload.
Old Feb 14, 2008 | 09:43 AM
Timmerduder
I looked at the suspension pretty hard and see no difference.... springs, shocks, now I did get the heavy duty package on my Mega Cab but I think they all do.
I looked at the GVW and it is exactly the same as the2500 and my front leveling kit was for a 2500 and if I get the air ride for the rear it will be for the 2500.
Thanks for all the input!!!
Old Mar 19, 2008 | 10:06 PM
coats_ne's Avatar
coats_ne
I looked up the part #'s on suspension components of both the 1500 and 2500 megacabs. Everything was exactly the same except the rear leaf springs. But the 1500 megacab has more leafs than a 1500 QC and the same # as the 2500. I even measured the two with a micrometer and there the same thickness. Go figure huh? What I do know for sure is that my 1500 mega rides like a 2500 and my 8000lbs camper only sqauts it about 2in., no eqaulizer hitch either. So in my opinion I would call a 1500 megacab a heavy half at the least.
Old Mar 20, 2008 | 09:46 AM
Timmerduder
From some other posts it looks like if you get a "standard" 1500 Mega Cab you get a 9 1/2" rear end but if you upgrade you get a 10 1/2" rear end. That is the ONLY difference I have found besides what I said in the initial post.
Thanks again!
Old Mar 21, 2008 | 05:01 AM
VA4MEDS's Avatar
VA4MEDS
I've got the Tow Pkg. w/10.5, 4 wheel ABS, etc. Mine rides super nice.
Speed Safely,
AL
