Just hit 30K below are the problems ive had so far
Old Feb 15, 2008 | 03:38 PM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: Just hit 30K below are the problems ive had so far
25K on my 05 Hemi, only thing I had to take it in for was the new and improved door seals.
30K is a magical number, DO YOUR 30K maintenance!!
Curious, did you change your differential fluid at 15K?
Old Feb 15, 2008 | 04:58 PM
RamItOne's Avatar
RamItOne
changed the diff a few k miles ago, used amsoil.
No clue why they call for a change so often. Buddy has a 2002 80k never changed it. No issues. Was reading on another board where ford calls for it at 150 000miles.
Old Feb 15, 2008 | 05:01 PM
CarGuyOhio's Avatar
CarGuyOhio
It is because of the C-Clip issue. They figure if you open it and catch a broken clip laying at the bottom it will save them (Dodge) money if still under warranty as you will not need a whole new rear.
At least that is my theroy as to why.
Old Feb 15, 2008 | 06:47 PM
Aladin Sane's Avatar
Aladin Sane
02 56,000 K - Recall B20 Axle flange / Recall C10 side mirrors / Recall C11 Blower / Recall G28 Shift Lever Blocker / Water Pump / Power steering line. Having a humming sound from tranny in Rev now. Rust over the back wheel wells and starting to replace the speakers. This truck was the first of the third generation it was love at first site. No complaints
Old Feb 15, 2008 | 10:16 PM
manogmin's Avatar
manogmin
2003 50,000 mi. no problems except the c-clip issue, got me a new rear end for 100.00 nothing other than that, but i got a feeling that ill need a new switch on the driver door in little while.
Old Feb 15, 2008 | 10:51 PM
mikebol's Avatar
mikebol
04 QCSB 4x2 HEMI with 78k+ on her. So far I've had to replace the passenger side wheel bearing, a set of 4 tires, the drivers side sunvisor and lots of 89 octane fuel.
Mike
Old Feb 15, 2008 | 11:07 PM
EspoMan's Avatar
EspoMan
I had problems with my 07 the day I took it home lol. None of the lights inside worked, including the dashboard. I am still having problems with it too. Look @ this: https://dodgeforum.com/m_1161037/tm.htm for more info.
Old Feb 16, 2008 | 04:58 PM
cyclone429's Avatar
cyclone429
06 2500 ram 5.7 6sp.
40,000 Km
One N. safety switch ( criuse control quit working )
Thats it !!!!
Truck now has the odd ratle in the dash area, but This is the best truck to date I have owned, My 04 F-150 5.43v was close to being rebulit twice at the same KM ...
Old Feb 16, 2008 | 07:42 PM
wildbill06hemi's Avatar
wildbill06hemi
'05 Ram 1500 5.7 4x4. 32K. No problems at all
Old Feb 16, 2008 | 07:47 PM
WhiteBerry's Avatar
WhiteBerry
06 1500 4.7 6sp 4x4, bought with 4 miles on it in 07. 21000, no problems at all (knock on wood)
