Tuff Country Leveling Kit
I have a 2005 Dodge Ram 1500 4x4 QC. Right now I have the torsion keys tightened to raise the truck up more to give it a level look. I am doing research on this leveling kit and it looks pretty good. My questions are as follows;
1. What is the biggest tire size I can use with my stock 20' rims?
2. Do I have to install new socks after I install the leveling kit. I read that I should if I go off roading. I don't go off roading just the potholes in NYC.
3. Do I need a wheel Alignment after installation?
If anyone can answer these questions I will really appreciate it alot.
you may or may not need new longer shocks. if it isn't for offroading i think that turr country kit claims that it keeps the stock ride which would meen that you wouldn't.as far as an alignment...yes. you sould always get and alignment after adjusting anything with the suspension. heck you should have even gotten an alignment after tightening the torsion bars.
Thank You Aeils.....When I jacked up the Torsion bars the first time I had a wheel alignment done. Now the only question I need to find out is whats the biggest tire size I can put on with this leveling kit. I heard 35" but I doubt it.
