Differential
Differential
Hi there!
I am brand new to the forum and have joined because I've just purchased an '03 Dodge Ram, 1500, quad cab, V8 truck. So far, I really like it... more power than I'm used to after having an '04 Jetta. I have a question: I was told that the differential was fine, but that it showed a little moisture because when it was previously checked (case taken off), oil was spilled. I've had Sears auto look at it as well as Firestone - neither of them did work on it because they said it was fine. My neighbor said to have a third auto shop look at it. I'm not sure if he just wants to be right or if I really should take my truck back in. It just seems to me that either Sears or Firestone would have been happy to take my money and do the work on the differential if I needed it, but instead they said it was straight. I look forward to getting acclamated (sp) with the forum.
Michele
Michele
RE: Differential
ORIGINAL: tys03dodge
Kurt
RE: Differential
Hi Kurt,
Thanks so much for your response. To my knowledge, the truck has never been submerged in water, I know for a fact that there is no noise nor is it leaking anywhere in the differential. My neighbor just stated that the differential appears to have "moisture" on the casing (as if it has been in water). Thanks for the advise... I'll clean it and keep an eye on it to see if it remains clean/dry.
Regards,
Michele
Regards,
Michele
RE: Differential
The truck need not be submerged in water for water to get into the differential, only the axel (and a bad/disconnected snorkel tube). This can happen if the truck is used to trailer a boat. As for “moisture” on the case, that’s fine.
I have to ask, by moisture, do you mean residual oil? If so, just look for oil stains on the ground where the truck regularly sits overnight. Also, check the level every once and a while by pulling the fill plug (while the truck is on LEVEL GROUND) and ensuring the oil is topped right to the bottom of the hole. Many times once the rear end has been opened, they can have small leaks due to improper sealing. This may be what your neighbor is talking about. If it's leaking, you could try to have the mec. who did the job, re-do it, but good luck! Not to mention, if he didn't do the job right before, I would reconcider using him for future jobs.
Kurt
Kurt
