'06 Speedometer Question
Old Feb 19, 2008 | 09:56 AM
VA4MEDS's Avatar
VA4MEDS
Default '06 Speedometer Question
I have to install a different speedometer cluster because mine was damaged in an attempted theft of my Nav System.
Does anyone know if I will retain my mileage on the old unit because it was likely stored on my computer?
Or will it reflect the mileage of the replacement unit?
I already know about the many different units available & the TMU on the title.
Thanks in advance.
Speed Safely,
AL
Old Feb 22, 2008 | 01:42 PM
VA4MEDS's Avatar
VA4MEDS
Default RE: '06 Speedometer Question
Any ideas on my previous post?
I found a cluster but it has too many miles if it stays the same as it is now.
Dodge house has no idea if miles are stored in the computer or not.
Speed Safely,
AL
Old Feb 22, 2008 | 01:56 PM
RamItOne's Avatar
RamItOne
I can only go off of logic and say once installed it'll revert to what the CPU in the dodge had. Otherwise it be pretty easy to lie about mileage on your veh when selling it buy just buying a unit with lower mileage.
Old Feb 22, 2008 | 02:37 PM
CRMRAM's Avatar
CRMRAM
ORIGINAL: RamItOne
True, Your Milage is saved to your CPU and NOT your cluster.You can switch as many times as you want and you will retain the same milage.
Old Feb 23, 2008 | 07:08 AM
VA4MEDS's Avatar
VA4MEDS
CRMRAM & RamItOne
Thanks so much for the info.
Now I don't have to worry.
Speed Safely,
AL
