stock springs with performance cam???
Old Feb 19, 2008 | 09:23 PM
allena9's Avatar
allena9
Member
Default stock springs with performance cam???
can you use the stock springs with a new cam such as the comp xfi273 or do you just absolutely have to get new ones. and has anyone put a larger cam in with stock springs how did it work out??
Old Feb 19, 2008 | 09:30 PM
CRMRAM's Avatar
CRMRAM
Default RE: stock springs with performance cam???
I have seen people run the 6.1L cam in there 5.7L with the stock springs and have no problems.The ones I know who had the problems were the ones whoinstalled the Comp Springs.
Old Feb 19, 2008 | 09:35 PM
allena9's Avatar
allena9
Member
geez really i didnt know that... but i have heard about puttin that cam in there but does it even hit any harder at all or anything?? cause i like the pretty rough idle sound and thats what i wanna go for.. what if i put that comp xfi273 cam in there with the stock springs?
Old Feb 19, 2008 | 09:45 PM
CRMRAM's Avatar
CRMRAM
The 6.1L cam wont give the rough idle your lookin.If you DO put a Larger cam.then spring replacement is a must.try KRCPerformance.com they offer all sorts of performance parts for the hemi.They could have just what your looking for and they could answer your questions more precisly.You can also try Sharadon Performance.I dont remmember there website address but if you search it on yahoo it should pop up.
Old Feb 19, 2008 | 09:52 PM
allena9's Avatar
allena9
Member
alright thanks.. but here is a link of the sound im looking for... either on of these see if you could maybe help out..
http://youtube.com/watch?v=dACFsEnqQ...eature=related
http://videos.streetfire.net/video/2...17011eff76.htm
http://videos.streetfire.net/video/8...12015da1ef.htm
http://videos.streetfire.net/video/f...170119913b.htm
all these sound great
Old Feb 20, 2008 | 02:08 PM
helopilot's Avatar
helopilot
You won't be able to tune a comp 273 and the power is too high up, you won't be able to tach it to 7000 rpm which is what is needed with the 273. About the biggest you can go is a 268 and you will still have to piggyback it in order for it to work right.
Old Feb 20, 2008 | 06:46 PM
allena9's Avatar
allena9
Member
what do you mean piggyback it??
Old Feb 20, 2008 | 08:10 PM
HammerZ71's Avatar
HammerZ71
Piggyback is no longer needed since the SCT tuner is out with Hemi support. I think Marty at KRC has even tamed the 273 with it...
Back to the original question, yes with any cam upgrade, you should upgrade the springs & retainers. Although some people have upgraded to mild cams like the 6.1 or 260 without doing the springs with no reported problems........ yet.
Old Feb 20, 2008 | 08:18 PM
HammerZ71's Avatar
HammerZ71
ORIGINAL: allena9
A plug in module that allows for changing A/F ratio's and other engine specifications to allow for proper performance with different duration ranges of upgraded cams.
Previously the only way other than a custom tune to tame an aggressive cam to work properly.
Old Feb 21, 2008 | 12:46 AM
Hellbilly1's Avatar
Hellbilly1
i cant believe your gonna cam it just for the sound?? thats crazy
