Weird smell?
Old Feb 21, 2008 | 04:35 PM
trfdeng's Avatar
trfdeng
Default RE: Weird smell?
Looking at the Hanes Manual you can pull the Glove Box out and the intake for the recirc housing is behind there. Get some disinfectant with a long spray tube and point it toward the evap core (twd the left) spay IAW manufacturer recommendations. Run the heat for 10 mins in recirc to dry out system prior to.
Old Feb 21, 2008 | 06:19 PM
kenihemi's Avatar
kenihemi
I'm bettin on a little critter too.
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Sounds like fungus/mold on the evaporator, like Cactus and trfdangsaid.
Old Feb 22, 2008 | 07:01 AM
sddunn2's Avatar
sddunn2
use the lysol trick it will work !!
good luck
Old Feb 22, 2008 | 09:15 PM
2007 st's Avatar
2007 st
mildew, mold. my 07 has it too. their is a tsb on it, ask your dealer or i will look for it. tsb fix was pretty much what a few guys here said to do. get to the evaporator core and spray some lysol on them. then run the heater. hope this helps.
Old Feb 28, 2008 | 09:38 AM
2005cobrakiller's Avatar
2005cobrakiller
id just fart a lot smell ur own smells lol
Old Feb 28, 2008 | 09:39 AM
2005cobrakiller
then again mine smells like weed so who knows
Old Feb 28, 2008 | 12:37 PM
usnfirefighter's Avatar
usnfirefighter
If it's a fishy smell, make sure no one played a joke on you and put sardines or fish oil in your air box..... (Not that I ever did it) But Have seen it done......
Old Feb 28, 2008 | 11:38 PM
Deuce1's Avatar
Deuce1
I used to work at a dealership. Long story short, a gentleman brought his truck in for the exact same problem. It basically smelled like shi@te. We eventually took apart the dash and found a rats nest. Mama and three babies died in the dash.
Old Feb 29, 2008 | 12:37 AM
pcollins's Avatar
pcollins
ORIGINAL: Deuce1
Omg... I wont be opening that bitch up anytime soon. LMAO
