Need Help PLEASE!
Old Feb 22, 2008 | 03:09 PM
trfdeng's Avatar
trfdeng
Default Need Help PLEASE!
Ill explain it the best I can. Started truck, backed truck up, pulled forward and almost stalled. Any ideas. Had the truck for about a month and Im getting the feeling that Im going to have to pour money into it. [:@][:@][:@][:@][:@]
Old Feb 22, 2008 | 03:12 PM
CRMRAM's Avatar
CRMRAM
Default RE: Need Help PLEASE!
How many miles on her?Did you warm her up before you took off?Did you press the brake before shifting into different positions?(Thats pressing the brake and comming to a full stop then shifting)
I have had this happen to me once in my 4.7L and it never happened again.
Old Feb 22, 2008 | 03:15 PM
trfdeng's Avatar
trfdeng
Cant say I let her warm up, but let the oil pressure come up and i did stop before i shifted. 57,6 and change on her.
Old Feb 22, 2008 | 03:18 PM
CRMRAM's Avatar
CRMRAM
Has it done it frequently or is this the first? If its the first run it for a while and see if it does it again.Let her warm up a bit,it should help out.
Old Feb 22, 2008 | 03:22 PM
trfdeng's Avatar
trfdeng
Ok heres where the weird comes in. I dont notice it in the AM but I do when I leave work. But in the AM I just go straight out of my drive. But Ill give it a shot its happened twice. Also after a can of seafoam.
Old Feb 22, 2008 | 03:35 PM
CRMRAM's Avatar
CRMRAM
Becareful with that seafoam stuff.Blew a head gasket on my honda civic because of it.Seafoam sometimes desolves the carbon that may have kept a seal which actually did good for your engine.Try running your engine for a few hundred miles and see how it works.
Old Feb 22, 2008 | 03:46 PM
trfdeng's Avatar
trfdeng
Used the Seafom cause Ive heard nothing but good things about it. Since Im about to hit the 60K mark Im going to go and geta tune-up on monday.
Old Feb 22, 2008 | 03:53 PM
trfdeng's Avatar
trfdeng
Stealership going to look at it Monday. I hope its something that is covered under the 7/70 warranty.
