How to remove the hedliner, A and B pillars and overhead console?
I need to remove all of these things to get my interior done for a show in May. Need to remove the headliner to re-ohpolster it and need to remove the pillars and console to have them painted. I've tried already but no luck and didnt want to break anything. Any info would be great.
TheA pillar molding is removed buy the grab handles, there is two bolt covers on each handle remove them. Then there is two 10mm bolts on each one take them out and you a pillar molding is off. The B pillar pop the cap off the seat belt height adjuster, there is I beleve a t45 tork bolt there take it out, then just pop the pillar cover off. It will be a bit tight there isa bunch of clips there. The Evic comes down buy removing the bulb covers (Be careful)there should be a couple of screws there, then it just comes off. Hope this helps is it very simple to do.
