Dodgeforum.com SLOW??
Old Feb 25, 2008 | 05:08 PM
  #21
oefootball_70's Avatar
oefootball_70
Default RE: Dodgeforum.com SLOW??
ORIGINAL: bwhite757
Right now I'm at home, DSL, 3.0 Mb down and 1.5 Mb up speed, it takes me an average of 2 seconds for threads to pop up in their entirety... I use Firefox web browser with the broadband speed tweak. If any of you guys out there use firefox, you should do the speed tweak:
This only applies to BROADBAND internet users:
[blockquote] Here’s something for broadband people that will really speed Firefox up: 1.Type “about:config” into the address bar and hit return. Scroll down and look for the following entries: network.http.pipelining network.http.proxy.pipelining network.http.pipelining.maxrequests Normally the browser will make one request to a web page at a time. When you enable pipelining it will make several at once, which really speeds up page loading. 2. Alter the entries as follows: Set “network.http.pipelining” to “true” Set “network.http.proxy.pipelining” to “true” Set “network.http.pipelining.maxrequests” to some number like 30. This means it will make 30 requests at once. 3. Lastly right-click anywhere and select New-> Integer. Name it “nglayout.initialpaint.delay” and set its value to “0″. This value is the amount of time the browser waits before it acts on information it receives. If you’re using a broadband connection you’ll load pages MUCH faster now!
Again, I've never had a problem with this website, and I'm on here quite ofter from various locations across the country... I don't believe the problem you are seeing is on their end, otherwise I would have to be seeing some of the slow speeds you guys are complaining about...
[/blockquote]
Dang that sure sounds like it will help. When I get back to my dorm I am deff gonna try this on my mac. This forum does seem slow compared to the other I used to visit.
Old Feb 25, 2008 | 07:38 PM
  #22
CarGuyOhio's Avatar
CarGuyOhio
Go here, pay attention to post 24 and 30. That is your fix for this site and others running the same software. Please post results of applying 24 in that thread.
https://dodgeforum.com/m_1145962/mpage_2/tm.htm
