Replacing 3 Dash tweeters,, any advice
Old Feb 24, 2008 | 10:06 PM
Alaska700's Avatar
Alaska700
Default Replacing 3 Dash tweeters,, any advice
Im putting together a new soundsystem, for the truck
I wanted to ask what did you do for the 3tweeters?
How did you wire them up?
Did you buy the Component system?
What sounds good?
thanks in advance
Old Feb 24, 2008 | 10:53 PM
jpeterson8's Avatar
jpeterson8
Default RE: Replacing 3 Dash tweeters,, any advice
personally I use the Kappa infinity series components
http://www99.epinions.com/Infinity_K...ay_~full_specs
they are a very good sound and I hooked them up to a 2 channel amp, the crossovers work great too. It's a good setup. You can get it in 5.25 or 6x9 as well, I have the 6.5
Old Feb 25, 2008 | 12:09 AM
Alaska700's Avatar
Alaska700
JP
So what did you end up doing about the Middle tweeter?
Old Feb 25, 2008 | 03:58 AM
StevenMoffettKY's Avatar
StevenMoffettKY
I'm really interested to see how this thread develops, as I'm just getting into upgrading my sound system.
Old Feb 25, 2008 | 04:52 AM
kpreston's Avatar
kpreston
if your truck came factory with the factory middle tweeter than just leave it in. It doesn't really make that much of a difference. But with the 3.5 in the dash i used fosgate and i ran the wires behind the dash and hooked them in straight to the radio(front outputs). sounds great and was cheap. i used pioneer 6/9 in the doors and the rear i left stock because i had a box built at one time that actually covered the rear speakers and i was unable to hear them anyway. i myself am getting ready to upgrade everything to the infinity kappa system thought. it sounds very clean and crisp, even at extraordinary sound levels. good luck man.
