Pyrometer Install
Old Feb 25, 2008 | 12:55 AM
R8DRROB's Avatar
R8DRROB
Default Pyrometer Install
I had a question for some of you CTD guru's. I followed some instructions that I found in the Cummings Forum on how to install an EGT Gauge. It told me to use a 7/16" bit and a 1/4"NPT tap. Well come to find out the fitting that came with my Auto Meter EGT gauge is 1/8".So my question is thiswhere canI get an 1/8" x 1/4"fitting.Im not sure if brass would hold up under those type of temps. Any help here would be appreciated. Thanks
Old Feb 25, 2008 | 01:07 AM
motorider228's Avatar
motorider228
Default RE: Pyrometer Install
Why don't you try out the cummins section, you will have better luck there getting the answer you need.
Old Feb 25, 2008 | 01:30 AM
R8DRROB's Avatar
R8DRROB
I didn't relize there was a CTD section.
