fog lights
Old Feb 25, 2008 | 01:09 AM
babyblackram's Avatar
babyblackram
Default fog lights
i just bought a 08 ram 1500it already had the pigtail hanging down for the fog lights, so i took my foglights off my 05 and plugged them in i would like to do something like the jumper wire pin 85 to 86 like i did on my 05 but from what i have read thats not possible. so if they are plugged into to factory pigtail all i should have to do is get a factory switch with the fog light control???? or could i just wire them directly to the parking lamps because i want them on whenever my lights are on. thanks for any advice oh and whats this i have heard about getting them programmed???
Old Feb 25, 2008 | 10:10 PM
2007 st's Avatar
2007 st
Default RE: fog lights
IF YOU PUT THE FACTORY SWITCH IN THEN YES YOU WILL NEED THEM PROGRAMMED. I THINK A COUPLE OF GUYS ON HERE HAVE WIRED THEM INTO THE PARKING LIGHTS. DONT REALLY KNOW IF IT WORKS OR NOT, SOUNDS LIKE IT WOULD.
Old Feb 25, 2008 | 10:27 PM
HammerZ71's Avatar
HammerZ71
Some report that just getting the switch worked and some have had to have the PCM updated. But yes, I would imagine if you wired straight to the parking lights would work.
I installed a set of Recon cab lights on a friends Chevy for him, and unlike our trucks, he had no harness in the pillar, so I just ran a wire to the parking light relay in his fuse box. I don't see why your fog lights should not work the same way...
Old Feb 25, 2008 | 10:47 PM
Parts/Service's Avatar
Parts/Service
To do it right, get an new headlight switch. I have installed a boat load of these. Sometimes they come on and work when the high beams are on and sometimes you have to have the "front fog light output" enabled by a dealer..Hope this helps...DAVID
